SCAL 6 Change registration Mark default print setting
Posted: Mon Mar 04, 2024 6:06 am
by Hairac
Hi all! There's a way to make the "print registration marks" setting in the print menĂ¹ to be always checked by default? I often forget to check it and i rarely do not use reg marks, so i'd love to not have to worry about it.
Thank you!
Re: SCAL 6 Change registration Mark default print setting
Posted: Mon Mar 04, 2024 11:13 am
by SandyMcC
You don't mention which cutter you're using but for all of the models I personally support, if you wait to print once you've entered the Print+Cut window, then Print Registration Marks WILL always be enabled:
Note that it makes sense for it to work this way because we're seeing an increasing number of people designing and printing from sublimation applications and not using reg marks because they're not cutting. So, they can continue to use File>Print and NOT have to remember to turn off that option while those doing actual Print+Cut can print from that other window and NOT have to remember to turn them on. :)
