Bed
Smelly
Bed
Post by Smelly »
here is a bed .svg file but I dont know how to get rid of the line extending up from the pillow.
bed.svg
Bed
(8.3 KiB) Downloaded 262 times
Kelly
jennifer mcquillan
Location: Dartmouth, Nova Scotia Canada Using Scal2, Inkscape .47, Vista
Re: Bed
Post by jennifer mcquillan »
Here it is without the line on the pillow. :)
bed.svg
(8.24 KiB) Downloaded 254 times
Smelly
Re: Bed
Post by Smelly »
thanks.. how did you do that?
Kelly
jennifer mcquillan
Re: Bed
No problem. I'm pretty new at this. So I have been watching and reading a lot of tutorials. HeatherM site has great ones and Scrappydoo is good also. All I did was put it on the node function(the one under the arrow) and in the left upper corner there is a plus and a minus sign and you click the nodes (the squares you see on the object) then click the minus. You keep doing this until all the nodes you want are gone. :)
Smelly
Re: Bed
Post by Smelly »
i am very very new... I have watched a few of Heather's stuff too. I will check out scappydoo's too
Thanks!
Kelly
Re: Bed
Hi, I saw your wonderful bed and then read about the problem with erasing the line. I used to use the node tool but then I discovered the eraser in Inkscape 0.47
Yesterday I posted a video tutorial on how to use the eraser in Inkscape 0.47. This may be easier than deleting nodes if you are using Inkscape .47
Here's the post with the link to my Blog post of the tutorial.
http://forums.surecutsalot.com/viewtopi ... 17&t=10365
Smelly
Re: Bed
Post by Smelly »
o that looks much easier!
Kelly
