Cutting size error
Posted: Fri May 12, 2023 3:46 am
Hi all,
I have an issue with scal 5 pro and its that it cuts small items perfect in size but if I cut the same item 2-3 times larger it is 1.3mm to large. o I adjust the scale and get that right then the smaller parts are to small. Im using a smurf cutter but it said its accuracy is very good. Is there a crossover where by you need to rescale items if they reach a certain size? How small an adjustment can you make in the scaling for the cutter settings, I went from 25.625-26.635 and it wouldnt save it. If you can help me here Id be very greatful.
TIA
Kenny
PS
Just to add the parts are the same sizes in SCAL and CAD.
TIA
Kenny
PS
