Stampin Up Christmas Ornament
Re: Stampin Up Christmas Ornament
Wow, that is beautiful, Maureen! Thank you so much for sharing it. You did an amazing job putting that all together.
Stampin up just issued a kit for a faster to put together simple version. the pdf instructions are http://204.228.150.61/holiday2012/ornam ... ctions.pdf I thought you ladies might like this easier version as not so many bits to cut out and stick together than the original.
The eagle eyed inkscape peeps (I am such a novice yet) will see in the pdf that now the ornaments are essentially rotated clones , 5 at 72, I just very quickly imported the ornament svg (I have My digital Studio) and added a circle in the middle and used my newly downloaded inkscape plugin to send to e-cal. Lots of playing to be done before I can print and cut it out!
I did try a print and cut outline but can't get it without 'holes' not blackout. If anyone knows what i'm doing wrong in Ecal please let me know. I'm guessing its something simple /obvious!! (just not to me)
I wanted to make mats for a lovely memory box die I have but can't work out how to loose the holes, if I edit the shadow and take out the extra nodes /holes they just keep coming back when I cut. Is there some way of cutting the tie with the original so the shadow blackout stays blackedout?
- Ornament Keepsakes - ornament round.PNG (103.66 KiB) Viewed 4223 times
*Eclips* with Ecal (Now dead)
Owner of purple E-Craft from hell.
Used to own old Cricut.
Scal3
Scal3
Maybe you could export the blackout for an svg and bring that back in somehow...just a thought.
i'llgive that a try, thanks
x
x
Scal3
Scal3
Thanks so much for the svg file !!!
Here is a file for the stamp on the back of the ornament in both SCAL & SVG
- Joy at Christmas.svg
- (47.11 KiB) Downloaded 350 times
- Joy at Christmas for back of ornament.scut3
- (225.84 KiB) Downloaded 260 times
thanks so much for the files!!!
