larger box with smaller compartments inside
Re: larger box with smaller compartments inside
A day later and I have added this one to my blog. :D
mlcadieux
Post by mlcadieux »
Thank you for the measurements on your blog. I did cut it out once and my little boxes were two small for the outer box. I hadn't played with the sizing yet, so thanks for doing all the work for me. Now I gotta cut a couple more boxes, I just have to say that the people on this forum are awesome.
mlcadieux
Post by mlcadieux »
Here are some pictures of my finished one. Thanks to those that helped me out.
side view.jpg (55.26 KiB) Viewed 3586 times
happy2scrap56
Post by happy2scrap56 »
I can't get the inside boxes to fit in the box.
What size should I put in the measurements so they come out right?
the box on right of scal where you input sizes is confusing to me... Height width
I have the expressions and would like as big as I can get. Would some one tell me how to do this?
here is a pic
ScreenHunter_01 Dec. 17 13.35.gif (82.27 KiB) Viewed 3580 times
talanhart
Post by talanhart »
mlcadieux wrote:Here are some pictures of my finished one. Thanks to those that helped me out.
That looks great!
DogCarbon
Post by DogCarbon »
happy2scrap56 wrote:I can't get the inside boxes to fit in the box.
here is a pic
If you are using my file:
When I created the file, I assumed the inside little boxes would be 3" squares when finished.
So the top would be 9.404 x 9.404
Bottom would be 9.50 x 9.50
and the inside pieces should be 6.113 x 6.113
If you are using HeatherM's file, on her web site she give dimensions too.
happy2scrap56
Thank you so much for giving the measurements.....Heather gives height and not width, and that is why I asked for help. I am so bad at measurements and if its not (spelled out exactly for me )than I can't do it.
I have cut this at your measurements and it came out perfect.
Thanks Again
Jan
talanhart
Post by talanhart »
Jan,
If you check the "Keep Proportions" box and enter a number for the height, the width will scale proportionately and vice versa.
happy2scrap56 wrote:Thank you so much for giving the measurements.....Heather gives height and not width, and that is why I asked for help. I am so bad at measurements and if its not (spelled out exactly for me )than I can't do it.
Thanks Again
Jan
Jan,
The heights for my files were given more for SCAL1 than SCAL2. If you have SCAL2 the files should import at the size needed for a 6x6 box. If you have SCAL1, you can set the default height at the height I listed before importing the file and the files will import with the correct proportions. Though for this set of my files the height and width are the same.
As Todd said, If you want to resize the boxes, just make sure that "Keep proportions" is checked and the width will take care of itself. HTH
happy2scrap56
Thanks Heather
