Page 2 of 2
Re: Unable to open .svg created in Inkscape
Posted: Sat Mar 23, 2013 6:47 am
You might need to change your X11 settings. Check out this topic: viewtopic.php?f=16&t=8347
Posted: Sat Mar 23, 2013 7:28 am
Hi, You did a great job explaining what you did, and with what it makes it so much easier to figure out.
I've opened your file and: It is not an svg but a grouped image. You can tell by looking at the very bottom info line under the color bar. I don't understand how that happened unless you inadvertently saved the wrong image.
ungrouped it
trace bitmap with these settings
colors: 2
Unstack
remove background
it traced just fine, just hard to see with the color fill pink.
I changed the stroke to black and removed the fill. If I remember correctly scal2 likes things stroked.
Delete the "image" and save
It opens in eCAL, I will attach the file.
I don't have scal2 anymore but if you have problems opening it someone *HeatheM" will pick up and finish the explanation. SCAL does not particularly like TEXT and most of the time text will not trace nicely in Inkscape for SCAL,
I did this with mountain lion.
Posted: Sat Mar 23, 2013 9:16 am
by luvs2scrap
HeatherM and papasue, thank you both for taking the time to research my problem!! I tried HeatherM's suggestion first (as it was the first one I read) and it WORKED!! papasue, I guess I forgot to mention that my original image had several colors and that the file that I attached was just one color of the original. Your mention of the information below the color bar was very helpful! I can now see that with the adjustment made from HeatherM's suggestion I know see that my image is now a Path (# nodes) and not just an image. Again thank you both for your assistance! Have a wonderful weekend :D
Posted: Tue Sep 15, 2015 9:54 am
by Snijderke
papasue wrote:Hi, You did a great job explaining what you did, and with what it makes it so much easier to figure out.
ungrouped it
colors: 2
Unstack
remove background
Hi papasue, thanks to your explination, i have the solution for the same problem I had.
When I imported a inkscape-svg-file, I saw only the image, without cutting lines; as you said: it was not a svg-file.
Thanks to yoy: i can now import my svg-files. Thanks, thankls, thanks.
greetings from belgium
Posted: Wed Jul 12, 2017 6:40 am
by acanais77
luvs2scrap wrote:I have the same problem, Error: Unable to load file. It is my first time creating a svg file from Inkscape, followed the scrappydew tutorial on youtube. Used the +SVG tab in SCAL2. Tried to embed and link (neither worked), tried saving as an Inkscape svg and a plain svg mutuelles Entreprise (neither worked), tried different combinations of those 4 options, nothing worked. Any suggestions would be greatly appreciated.
I especially think that you forgot to compress the document before sending. But hey, it's not necessary if it's not big volume.
