3 letter circle monogram
dragonlord666
Re: 3 letter circle monogram
Post by dragonlord666 »
OK here is the tut..... might be a tad big to upload here so I"ll upload to my skydrive and give the link
https://docs.google.com/file/d/0B_7MJ9o ... sp=sharing
this sometimes goes wrong so shout if it's not working and I'll see if I fix it :)
PLEASE DO NOT SHARE THIS LINK OUTSIDE THIS FORUM WITHOUT ASKING ME FIRST - THANK YOU
once you have this "basic" info you can experiment with different shapes - I know monograms are two or three letters, I wanted to see if four was workable - it is :)
the files I made during this tut are
Screen shot 2013-05-26 at 16.17.49.png (23.88 KiB) Viewed 7019 times
and
Screen shot 2013-05-26 at 16.22.16.png (18.42 KiB) Viewed 7019 times
Gaz
Computer:IMac running Mojave
GAZ, followed your link to the tut but it says I have to have YOUR permission to see it. So I'm waiting to see if you PERMIT me to view it. :D
mjgo
Post by mjgo »
When you have the time....it would be great.
dragonlord666
papasue wrote:GAZ, followed your link to the tut but it says I have to have YOUR permission to see it. So I'm waiting to see if you PERMIT me to view it. :D
hummm....... OK I"ll see if I can fix it..... or I have to give each individual permission <boggle>
give me a few to find out what went wrong this time
Gaz
dragonlord666
OK try it now..... I think (fingers crossed) it was the anyone with the link button, it did not register :x
Gaz
Works NOW! off to play with it.
TKS
mjgo
Post by mjgo »
You are FANTASTIC!! Thank you so much....I'll have a busy afternoon trying this. I was trying to use nodes to make the letters fit the shape. You way looks so much better. Thanks again! :D
dragonlord666
glad you find it worth it :)
all that should be able to be done in scal - you just need to find the corresponding commands like:-
inkscape path>exclusion = scal path>back minus front
Gaz
mjgo
Post by mjgo »
I seem to be having a problem when I get to path>exclusion. I don't know what I am doing wrong, but it isn't working for me. Maybe tomorrow...I will try again.
dragonlord666
let us know what is going wrong and we'll see if we can work out why.
one thing that can happen is the shape is not a path (the info bar at the bottom of the screen says one of the objects is not a path)
this normally means something is grouped - just select objects and look at the bottom bar, if you see it say group of X objects that's most likely the one causing the problem
or you can just select everything and object>ungroup - just be careful when moving things and this can leave bits behind like the centre of letters like "e" or "B" or "O" etc
Gaz
