Inkscape jpg to svg - svg do not show up in SCAL?
Re: Inkscape jpg to svg - svg do not show up in SCAL?
If you set the stroke around text in Inkscape you need to convert the stroke to cutting lines. Do this by selecting your text and from the menu use Path/Stroke to path. HTH
mikewozowski
Post by mikewozowski »
hi - thank you!
i have scal 2.
i have been playing with it and i did get what i was trying to do done using outset instead of a stroke, but the outset didn't give as crisp results as the stroke did.
this was what i was trying to use at first but i could never get the stroke to open up/ be recognized in SCAL2
this is what i ended up with by using outset. not exactly the same but i guess it will be ok. is there a setting i can change to get the outset to be "sharp" like the other?
mikewozowski
how do i post the SCAL file?
Mike right below the box where you type in your post message is the option to attach a file. You can attach the SCAL file there. Be sure to add file, you don't need to place inline like you do with a png or jpg graphic
Screen shot 2012-02-22 at 3.40.22 PM.png (53.97 KiB) Viewed 3218 times
