Sure Cuts A Lot 2.041 Update
Things we need you to know
craftedge
Site Admin
Post by craftedge »
New version (2.041) for Windows and Mac is available for download now on our site
http://www.craftedge.com/download
To update from a previous version 2, just download and install over the current one.
Make sure the program is not already open and running when installing the update.
* Fixed a problem where program would freeze/slow down when moving/sizing objects that have an image/pattern fill applied to it
* Fixed a problem with Text on path if trying to Covert Text to Outlines or Break Apart
* Fixed a problem with exporting PNG/BMP with rhinestones
* Fixed the Print option not bringing up the Print window
Narr
Re: Sure Cuts A Lot 2.041 Update
Post by Narr »
It's July 13th and there is no version 2.041 update on the link, has it been removed already. Help I need this fix. My program does not correctly work since I went to 2.030. Un/Fortunately I've been busy with yard work and not doing much crafting. Now I need it and I'm ......
the update is no longer available if you pm me your email I will send it to you tomorrow...
atanguay
Post by atanguay »
Where can I get this update? I do not want the 3.0 update, as we have the Cricut machine.
A
sstehman
Post by sstehman »
If you go to this link with CE for support and put in your request, you should get the latest version. I would take advantage of getting the SCAL3 version free (even if you don't have the cutter yet) as it is no charge to you at this point as long as you own SCAL 2.
http://www.craftedge.com/support/support.html
atanguay
Post by atanguay »
Ah!
Thanks for the link Sandy, but we need to stay with V2 since we have a Cricut (which I will never buy anything from again since I'm sure they've forced the end of support for SCAL).
http://www.craftedge.com/support/lostsw.php
You can fill out this form and the last mac download will appear at the bottom right after you complete and submit the form...very quick.
dudesuper
Post by dudesuper »
Would someone b able to forward the 2.4.1 update via email
There is only improvements going forward to the latest update located on the craftedge.com homepage for reinstalling
Just fill out the form and the download will appear right after you hit submit at the bottom of the page.
Otherwise contact support with any issues
They are very helpful. If there is some reason why you want the 2.041 just tell them.
