upgrade from create to expression
I have had a create and using SCAL 2, just got myself a expression and I am unsure if I an run my SCAL, do I need to do anything to get my expression to realise that it is connected to pc
Re: upgrade from create to expression
Turn on your Expression if the firmware version shows 2.1 or 2.3 you can "plug and play"...I have one of the colored Experessions and it was just plug and play...Just realize that the settings on the Expression and Create are different and you'll have to play with it to do what you want. It's exactly like playing around with settings when you got your Create.
I did the same upgrade and it took a while to get it dialed in.
If you aren't learning something new everyday you might as well just lie in a grave and wait for death.
- Contact:
I have an E with firmware 2.34 and it works just fine with scal2
