rosette file
lynnscraps
rosette file
Post by lynnscraps »
Does anyone have a file for the rosette flower that has score lines instead of the perforated lines such as on the Tim Holz die. I don't like how the perfs show thru the flower rosette. TIA
Soraya
Re: rosette file
Post by Soraya »
can you show a picture or a link for that, please
lynnscraps
Re: rosette file
This is a die with the perforations, which I do not like. I would rather have score lines. TIA:
scrapbookernana
Re: rosette file
Post by scrapbookernana »
letteringdelights.com has some rosette files, very reasonably priced. I purchased them but have not cut them yet; it looks like the score lines are marked but not perferated. hope this helps. Jeanette
Re: rosette file
http://forums.surecutsalot.com/viewtopi ... tte#p73281
Not sure if this one is still available...?
Soraya
Re: rosette file
Post by Soraya »
you can also cut a 2" or wider x 12" (depending on the size you want, and score it at each 1/4.
http://www.amazingpapergrace.com/christ ... -tutorial/
she has many good examples. I gtried to find a tutorial she has but couldn't. still, its worthy to have a look anhd get inspired;
Re: rosette file
What is the trick to keeping a rosette together? No matter how I try to hold them together they keep popping apart!
pennsylvaniakate
Re: rosette file
Post by pennsylvaniakate »
I've used a hot glue gun with success.
Re: rosette file
Thanks! I will get the hot glue gun out of the garage :) I am going to try again today!
UPDATE: Perfect...that worked GREAT!
I learned a tip once...to take the papers that people throw away at the post office that peel off the back of the large postage stamp labels...they have a shiney side like freezer paper. Anyway, I do this now and have them handy. I put one on the counter shiney side up and then positioned my rosette on the shiney side and put the hot glue all in the center and a bit on the fold edge there and then put on the flower center on that side...I let it cool and then turned it over and did the other side.
Thanks for the 'know how', Kate!
