These are the first two files I made in inkscape with the help of many (thank you all)
Hope you like them - let me know what you think
2 TITLES FOR PAGE LO'S
- snowfun.svg
- (53 KiB) Downloaded 490 times
- COOLDUDES.SVG
- (16.99 KiB) Downloaded 510 times
Re: 2 TITLES FOR PAGE LO'S
Unfortunately, I don't have any snow pictures to scrap right now, but I do have several that will work with the Cool Dudes title. The pair of sunglasses in Cool is very clever. I'll be using this one for sure!
Thanks for sharing. Hope to see more of your work!
Jeannie
Jeannie
Note that the snowflake title is not welded. You can do so in Inkscape: First select the 3 and delete it. Then, go to the outline view (View, Outline). Drag the mouse around all of the objects - letters and snowflakes to select everything. (For me, using Ctrl A does not let me weld, don't know why). Click on Path, Object to Path. Then click on Path, Union. Everything should be welded now. In Outline view, you will see some lines between the S and W - that is ok, has to do with vector drawing. Save the item and import into SCAL.
Thanks wreed - I think I fixed it.
- snowfun.svg
- (47.7 KiB) Downloaded 301 times
