Flipping a design
Flipping a design
I have a design with a cornucopia and "Give Thanks" that I want to flip so the lhe letters will read correctly when I etch it on the back of a plate. When I press the flip button, it does flip it but it the elements don't stay in the same relationship..........letters end up on top of cornucopia and some of the letters move themselves. Any ideas how to make this work. Thanks a bunch. Carol B
Re: Flipping a design
If you group it all together before you flip it they should stay in the right position in relation to each other. If it is not all grouped as one object it will flip in an awkward way. Under edit do a select all then under object do group. Hope that helps.
Michelle
Michelle
Thanks.........we went out to dinner and on the way it occured to me that maybe I had forgotted to group the elements together. I'll try that and if it doesn't work, I'll be back for more help. Thanks again Carol B
