Circle Border
AnointedHands
Circle Border
Post by AnointedHands »
Don't worry ladies and gents...there are only two pieces to the file cuz all the cutout will be on the mat and the outline is the border. This way, you won't have worry about pasting a lot of small pieces in place. However, you might want to use repositional adhesive.
Circle border and blackout 0421.svg
(47.68 KiB) Downloaded 214 times
jancy
Re: Circle Border
Post by jancy »
great file to use for dh's military pages :)
how did you do that top layer? I did it once in inkscape, but can't figure out how to do it again.
would appreciate any help, thanks!
AnointedHands
Re: Circle Border
Traced the bitmap.
Duplicated the trace.
Break Apart one of the traces
Combined the Inside and the outside circle, then removed all the little pieces.
Used the other trace as the outline.
jancy
Re: Circle Border
Post by jancy »
AnointedHands wrote:Traced the bitmap.
thanks!
there is an easier way to do it. I did it before with just 2 clicks---just can't figure out which ones :roll: . it has something to do with the lines........I'm determined to figure it out. will post that info if I ever do figure it out.
sboz
Re: Circle Border
Post by sboz »
Fascinating! Thanks so much for sharing!
Shari
Bug Safe: http://www.pbase.com/bugsafe/inbox
My Blog - "The Bug Stop" - where you can find my .cut files:
http://thebugstop.blogspot.com/
