New Features Added:
Sure Cuts A Lot 2.010 Update
Re: Sure Cuts A Lot 2.010 Update
Peachyscraps you would would have to have two items selected to get the path feature working.. Try with two squares overlapped.. select them both then look in your path option..
- Location: LAFAYETTE,LA SCAL1,SCAL2 ,SCAL 3 Windows 7 64 BIT,INKSCAPE.47,cricut personal.cricut expression
Thanks for sharing.
Helen
Helen
- Location: Australia -- Win-Vista, Scal2 2.043, Ink 0.46
You will need to install the file you downloaded.indytrishd wrote:I have downloaded the latest version three times. Every time I go back into SCAL2, it says there's a newer version. Why is it not reading the newest version for me?
Hopefully that helps
Cheers
Craig
Cheers
Craig
Craig
