Mickey Mesh
Mickey Mesh
I was at the Disney store in Times Square and there was an adorable place mat that looked like Mickey heads meshed and it gave me an awesome idea
- Bitmap Image if cut on 12x12 paper
- mickey mesh.png (110.44 KiB) Viewed 7709 times
- mickey mesh.svg
- Mickey Mesh SVG file
- (99.89 KiB) Downloaded 999 times
~Ashley
Psalm 113:3 Creations
Re: Mickey Mesh
I love these mesh files. TFS, will try to play with it this wknd!
Re: Mickey Mesh
I apologize that my file was not welded the first time and with all the newbies here thought I should fix it (even though it's been downloaded 400 times) So here is the corrected file!
- mickey mesh.svg
- correct mickey mesh
- (92.87 KiB) Downloaded 294 times
~Ashley
Re: Mickey Mesh
I'm definately still new. But it inspried me to learn to use the weld button and I got all of them together but 1. I love it though and it cut great. And now I'm ready to try and do something else on my own. Aw, I think I'm growing up. Wouldn't you know, just when the senior discount kicked in.
Thank you, great file.
Re: Mickey Mesh
Here's another quick tip: If it's a SVG file you can open it in Inkscape and select all (quick keyboard would be CTRL+A) and then go to "Path" and click "Union". After that, you should be able to import into SCAL and cut without having to weld. I think I made this file when I was still learning (I only had my Cricut for 2 months).
Never-the-less, it was my fault that I didn't do what I was supposed to!
~Ashley
Re: Mickey Mesh
I haven't really tried anything in Inkscape yet but hope to start learning it. Hopefully things will slow down a little with the holidays over. Thanks for that instruction. That makes it sound pretty simple. lol famous last words. Sounds alot easier than welding each one though. Man, there's so much to learn.
