Is there an easier way to rotate?
Tell us the features you want to see in Sure Cuts A Lot
Lynndee
Post by Lynndee »
now it just says rotate or skew in the properties box where you used to be able to input the numbers. is there any way to do a rotate without going to object and then transform and then to rotate? i use this function quite a bit.
thanks.
oddonesvk
Re: Is there an easier way to rotate?
Post by oddonesvk »
Hi Lynndee:
If you want to rotate by a specific number of degrees go to the top of the page and click on OBJECT / Transform / Rotate. That will open up a menu which will allow you to insert the number of degrees you'd like to rotate the object.
Lynndee
Post by Lynndee »
Thank you. I appreciate the info. It's a lot more steps now than the previous version. :(
craftylalia
Post by craftylalia »
Can we get a button to do a quick 90 degrees?
HeatherM
Post by HeatherM »
craftylalia wrote:Can we get a button to do a quick 90 degrees?
I second that. A 90 degree button with CW/CCW options would be great. ;)
talanhart
Post by talanhart »
Ditto on the 90 degree button. I was rotating artwork last Saturday quite a bit to get names to fit and this would have come in handy!
LiveLaughScrap
Post by LiveLaughScrap »
Yes, love the 90 degree button idea!!!!
Lori
Lori
LIVELAUGHSCRAP
A PLACE FOR SHARED CREATIVITY
http://livelaughscrap-leedle.blogspot.com
snowlady
Post by snowlady »
Thanks for the info on rotating. I was wondering about this yesterday.
