I have a problem with curves
Re: I have a problem with curves
Yes the issue is wiht text that contain curves S,C;D;B etc A T H do not suffer from this issue also elipses and rounds are hitting the same issue.
There is an issue with resolution in the build in Gcode to many points created when the object is sent to cutter.
Im giving up on SCAL a month later no updates i dont belive there will be any liked the software its verz inuitive but none the less maybe with some other cutter it will work.
i agree
