SCAL4 or SCAL5 or SCAL6 with legacy Cricut machines
Romayne
Re: SCAL4 or SCAL5 with legacy Cricut machines
Post by Romayne »
Same fpr SCAL5
Bingo! I may have found the issue. There's a slight difference in one of our preferences tabs in SCAL2 which indicates we're not running the same version. Go go Help>About Sure Cuts A Lot 2. Whatever version do you have? I"m on 2.044.
Romayne
Post by Romayne »
SandyMcC wrote:Bingo! I may have found the issue. There's a slight difference in one of our preferences tabs in SCAL2 which indicates we're not running the same version. Go go Help>About Sure Cuts A Lot 2. Whatever version do you have? I"m on 2.044.
I'm running V 2.030 I daren't change or update anything in case it stops the software working with the cricut completely lol
Well, I recommend downloading and installing the newer version 2 into a different folder so that you can test it out. Don't forget that the entire reason Version 3 was released was because of the law suit. Basically Version 2 cut to all of the Cricuts at that time and then, because of the law suit, SCAL released version 3 and moved on from there.
Also, I can post on Facebook and see if anyone is successfully using 2.044 to cut to a Cricut... if you like?
Romayne
Post by Romayne »
SandyMcC wrote:Well, I recommend downloading and installing the newer version 2 into a different folder so that you can test it out. Don't forget that the entire reason Version 3 was released was because of the law suit. Basically Version 2 cut to all of the Cricuts at that time and then, because of the law suit, SCAL released version 3 and moved on from there.
I thought about downloading 2 again but when I clicked on it on the craft edge site it opened up the window to download 5 so I don't know how to get to 2 to try this
This is the link to use in order to download older versions of SCAL.
http://www.craftedge.com/support/lostsw.php
Romayne
Post by Romayne »
SandyMcC wrote:This is the link to use in order to download older versions of SCAL.
Sandy you have the patience of a saint, for which I am extremely grateful because you got me there in the end. I just updated SCAL2 to v 2.044 and it only went and worked! Thank you so much for all your help with this :D
You're very welcome! And note that the reason I don't let these things go is because they're like a puzzle and I love puzzles. :)
james002
Post by james002 »
Cricut explore air 2 is my favorite. Its a great Vinyl cutting machine.
Romayne
Post by Romayne »
SandyMcC wrote:You're very welcome! And note that the reason I don't let these things go is because they're like a puzzle and I love puzzles. :)
I am usually pretty good with puzzles as well but had to admit defeat with this one :lol:
