It is currently Mon Apr 22, 2019 8:28 am
PostPosted: Wed Apr 11, 2018 6:04 pm
Hi there,
I have designed some artwork in Affinity Designer that I want to cut. When I export the file as an svg from Affinity and then import into SCAL 4 pro - it doesn't import the file.
When I am exporting the file as an svg from Affinity Designer I have the following options:
1. Present (with 4 options): SVG (for export), SVG (for print), SVG (for web), SVG (flatten)
2. Raster DPI (with 6 options): 72, 96, 144, 192, 300, 400
3. Export text as curves for font independence: tick box
I have tried a number of different combo's, however nothing is working.
Hoping someone knows the answer and can help.
Cheers
PostPosted: Thu Apr 12, 2018 8:43 am
I can certainly help you figure this out. I've successfully exported from Designer and then imported into SCAL4P. I cannot recall if it was SVG, however. I don't think so because I was testing the ability to "die cut" a raster image with a vector shape in Designer and then bring it into SCAL. So, I must have been exporting as PNG instead. But I'll see what I figure out.
PostPosted: Thu Apr 12, 2018 2:00 pm
Okay, I played with it and it's working for me. Regarding the export window:
First, let's say this is just a basic shape... no text:
File>Export, click on SVG
Preset (SVG for Export)
Raster DPI: leave blank, select nothing
Leave the rest at default
Click on Export
Name your file.
Now, let's say you have created some text while in Designer:
Mark the box for Export Text as Curves
The Preset box will become blank... that's okay!
Click on Export
Name your file.
PostPosted: Fri Apr 13, 2018 1:29 am
Hi Sandy,
Thank you so much - all working now!!!!
Kind Regards
PostPosted: Fri Apr 13, 2018 7:13 am
You're welcome! I'm glad you asked this because I really needed to check it out for others.
