It is currently Sat Feb 23, 2019 7:13 pm
PostPosted: Thu Apr 12, 2018 10:01 am
Hi. Can anybody possibly help me? I have purchased a Z13 from Foison (similar to the Silver Bullet cutter). When attelpting to cut multiple shapes I get a slight rotation on the cut image. I have carefully checked the rollers to ensure that they are spread uniformly along the media.
PostPosted: Fri Apr 13, 2018 7:17 am
The pinch wheels need to be centered over the grit shafts below. So pull out your mat and make sure that at least the outer two that would be near the outer edges of the cutting mat are ALSO over those grit shafts beneath.
If that's not the issue then report back your cut settings and details about the material you're cutting. By the way, you might benefit from referencing the following user manual I've written. The Maxx Air model is VERY similar to the Silver Bullet and is also made by Foison. Much of what is in this UM will probably also apply to your model.
http://www.iloveknk.com/support/knk-max ... port-page/
