It is currently Wed Jan 22, 2020 10:21 pm
Post new topic Reply to topic  [ 10 posts ]
PostPosted: Wed Mar 16, 2016 10:15 am
Hey Guys ive been searching for the last hour trying to find help and no luck so figured id join and hope some one can point me in the right direction.
my issue.
I'm using a us cuter SC model. and sure cuts a lot 3 pro
whenever I go to cut anything. words specifically. I'm cutting a basic font over and over to fill up the roll of vinyl and my plotter seems to jump from cutting the fist letter to cutting the 3rd letter then to jumping over to the second sticker to start cutting its 1st letter, then back to the 1st sticker. It doesn't seem to have any sense of direction. Its causing the letters to overlap.
is there a setting I'm missing or something so It doesn't jump around so much?
PostPosted: Wed Mar 16, 2016 10:38 am
I am not sure I understand but I'll try. If you have typed in words:
If it is the same word over and over did you copy/paste the word or did you use duplicate
are the letters overlapping a bit or are they separated?
can you share the file you are working on as it will make it easier to diagnose.
PostPosted: Wed Mar 16, 2016 11:34 am
The plotter cuts both R's
then jumps to the top to cut the stripes. Then back to cutting the lettering. It does something similar with anything else I cut.
PostPosted: Wed Mar 16, 2016 11:37 am
[imghttps://www.facebook.com/sbvinylco/photos/a.1599862780228192.1073741829.1581389345408869/1713838292163973/?type=3&theater][/img]
thisis what I'm cutting.
its cuts the R's then jumps to the top to cut the stripes, then back to the wording. Anything I cut does the same thing. Plotter just kind of jumps around to different sections to cut
PostPosted: Wed Mar 16, 2016 1:57 pm
The scal file would be more useful if you do not mind so I can see the construction and layers.
PostPosted: Wed Mar 16, 2016 4:45 pm
this is the .svg file.
rally your heart stripes amd website.svg [41.85 KiB]
Downloaded 95 times
PostPosted: Thu Mar 17, 2016 7:44 am
I've messed with this a lot and I can get it to cut nicely but it is still jumping around. I have sent the file to Craftedge to see what they think is going on. In the meantime here is an svg that does cut although there is still some jumping around. You will have to resize it up to your desired size as I am working on an eclips that won't go that large. Try and cut this one and see how you do....I'm still curious.
I'm using the latest version of Inkscape on a Mac
Craftedge might contact you soon.
rallyfinal.svg [23.36 KiB]
Downloaded 86 times
PostPosted: Thu Mar 14, 2019 10:06 am
Hallo, warum kann ich mit dem Hoobbycat nicht 2,5 Meter und 25cm Schrift schneiden? Es zeigt mir in der Vorschau an das nicht alles drauf ist und Plottet dann nur die Buchstaben die zu sehen sind .
Beispiel Frühjahrsangebot , das Angebot sehe ich nicht mehr dann , vieleicht hat einer ja einen Plan ???
PostPosted: Fri Mar 15, 2019 6:32 am
Die normale Version von SCAL darf nicht länger als 1,8 Meter sein. Sie benötigen die Pro-Version von SCAL, um längere Projekte zu schneide
PostPosted: Mon Mar 18, 2019 1:30 am
Ach, ja da war doch etwas ..stimmt ..nach langen hin und her hab ich es auch mitbekommen. Danke
