It is currently Thu Apr 18, 2019 3:46 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Wed Nov 19, 2014 10:52 am
- New enhanced interface
- Type on arch
- Snap to objects
- Rotated duplicate
- and more!
Pro Features
- Tiling
- Duplicate cutting
- Cut by color
- Color layer alignment
- 3D shadow
- Import DXF, PLT
Special Introductory Pricing:
For more information
Sure Cuts A Lot 4
Sure Cuts A Lot 4 PRO
PostPosted: Wed Nov 19, 2014 11:43 am
PostPosted: Wed Nov 19, 2014 12:21 pm
PostPosted: Wed Nov 19, 2014 12:41 pm
Location: North Carolina, SCAL-3; Windows 7-32 bit; CorelDraw 6x; Corel PhotoPaint 6x; InkScape 0.48.4 r9939
-DON-
http://www.TeesAndBeyond.com
Custom Garment Printing
PostPosted: Wed Nov 19, 2014 3:42 pm
PostPosted: Wed Nov 19, 2014 3:50 pm
PostPosted: Wed Nov 19, 2014 5:01 pm
PostPosted: Wed Nov 19, 2014 6:47 pm
PostPosted: Wed Nov 19, 2014 10:17 pm
When you come to the edge of all the light there is, and must take a step into the darkness of the unknown, believe that one of two things will happen.
Either there will be something solid for you to stand on, or – you will be taught to fly….
PostPosted: Wed Nov 19, 2014 11:51 pm
