Sure Cuts A Lot 4 Released for Windows & Macintosh
craftedge
Post by craftedge »
- New enhanced interface
- Type on arch
- Snap to objects
- Rotated duplicate
- and more!
Pro Features
- Tiling
- Duplicate cutting
- Cut by color
- Color layer alignment
- 3D shadow
- Import DXF, PLT
Special Introductory Pricing:
For more information
Sure Cuts A Lot 4
Sure Cuts A Lot 4 PRO
dmpecci
Re: Sure Cuts A Lot 4 Released for Windows & Macintosh
Post by dmpecci »
sstehman
Post by sstehman »
BigDude
Location: North Carolina, SCAL-3; Windows 7-32 bit; CorelDraw 6x; Corel PhotoPaint 6x; InkScape 0.48.4 r9939
Post by BigDude »
-DON-
http://www.TeesAndBeyond.com
Custom Garment Printing
sstehman
Post by sstehman »
palz11
Post by palz11 »
sstehman
Post by sstehman »
cydnew
Post by cydnew »
sandyhoy124
Post by sandyhoy124 »
When you come to the edge of all the light there is, and must take a step into the darkness of the unknown, believe that one of two things will happen.
Either there will be something solid for you to stand on, or – you will be taught to fly….
susibi
Post by susibi »
