- New enhanced interface
- Type on arch
- Snap to objects
- Rotated duplicate
- and more!
Pro Features
- Tiling
- Duplicate cutting
- Cut by color
- Color layer alignment
- 3D shadow
- Import DXF, PLT
Special Introductory Pricing:
For more information
Sure Cuts A Lot 4
Sure Cuts A Lot 4 PRO
Sure Cuts A Lot 4 Released for Windows & Macintosh
Re: Sure Cuts A Lot 4 Released for Windows & Macintosh
- Location: North Carolina, SCAL-3; Windows 7-32 bit; CorelDraw 6x; Corel PhotoPaint 6x; InkScape 0.48.4 r9939
- Contact:
I am truly confused. I have SCAL ver 3. Is it necessary for me to purchase SCAL 4 since I have a previous version? The replies to this are not clear on this question. ![Question :?:](./images/smilies/icon_question.gif)
When you come to the edge of all the light there is, and must take a step into the darkness of the unknown, believe that one of two things will happen.
Either there will be something solid for you to stand on, or – you will be taught to fly….
