How to get these to all cut at the same time!?
hollie1165
Post by hollie1165 »
I need the circles to cut out with all of the text. Please HELP!
DUE FOR DELIVERY T.scut3
(186.04 KiB) Downloaded 221 times
jrichards
Re: How to get these to all cut at the same time!?
Post by jrichards »
It looks to me like if the circle does cut it will cut off some of your letters. If you still want it to cut go to the shapes library and add a circle, then size it to the circumference you need(looks to be 6"), "Edit" , "Select all", and in the Path menu select "Union" . If you hit the preview button you will see that the circle will cut as well as the letters.
Jan
HeatherM
Post by HeatherM »
Don't use Pages, use Layers instead. Select the layers on a page, then from the menu use Layer/Send Layer to Page and select the page that you want to use. Do this until everything that you want to cut is on the same page.
