Hello,
I purchase SCAL Pro from USCutter about a year ago and just recently upgraded to a new computer. For some reason, my serial number on the cd package is not working to activate SCAL Pro. I had this problem before on my old computer, but I can't remember what I had to do to get it work. Any suggestions?
Serial Number doesn't work for activation
Re: Serial Number doesn't work for activation
atomicimprints wrote:Hello,
You must deactivate the program on the old computer before you can activate it on the new one. You can only use the serial for two computers at a time. Or call Craftedge if that is not possible.
Thanks for the reply. Actually, the problem was the serial number. I found an old email from US Cutter that explained the issue. Apparently the serial number has an extra "0" starting the first set of numbers. Once I removed that, I had to deactivate the other registration and was then able to activate the new installation of the software.
