Sure Cuts a Lot 3.0 for Windows & Macintosh
Re: Sure Cuts a Lot 3.0 for Windows & Macintosh
Carolyn
Carolyn
Carolyn
Carolyn
The answer is to contact craft edge support, point out the bug to them and ask them to fix it. if these things are not brought to their attention then they will not fix it because they are likely unaware of it!cmsmith64 wrote:I'm going to vent ... and just may-be someone has an answer for. I have SCAL2 and SCAL3 and use SCAL3 b/c I have a Silhouette Cameo which is compatible with SCAL3. I really like SCAL3 BUT I do not like going in to change the cutter from SD to Cameo everytime I load up the software program. I DO NOT like having to select layers so I can have the box showing layers. Why the change from SCAL2 where it was there when you loaded the program, plus Cricut always showed up as my cutting machine. I had to seek help from support just so I can have the virtual mat come up full size ALL the TIME. And b/4 I demanded a full size mat to come up, Cameo ALWAYs showed up ...NOW ...NOT. WHY
Carolyn
As for V3 vs V2..
If you have not contacted Craft Edge support about your problems then it is likely you are just one of many people who have not contacted them and you are all sat waiting for someone else to take the initiative.. Break the cycle and send the email
![Wink ;)](./images/smilies/icon_e_wink.gif)
Carolyn
Carolyn
Louise-Paisley wrote:The answer is to contact craft edge support, point out the bug to them and ask them to fix it. if these things are not brought to their attention then they will not fix it because they are likely unaware of it!cmsmith64 wrote:I'm going to vent ... and just may-be someone has an answer for. I have SCAL2 and SCAL3 and use SCAL3 b/c I have a Silhouette Cameo which is compatible with SCAL3. I really like SCAL3 BUT I do not like going in to change the cutter from SD to Cameo everytime I load up the software program. I DO NOT like having to select layers so I can have the box showing layers. Why the change from SCAL2 where it was there when you loaded the program, plus Cricut always showed up as my cutting machine. I had to seek help from support just so I can have the virtual mat come up full size ALL the TIME. And b/4 I demanded a full size mat to come up, Cameo ALWAYs showed up ...NOW ...NOT. WHY
Carolyn
As for V3 vs V2..
Donna in Montana
Donna in Montana
__________________________
