As in SCAL, there is no option for 'No Mat' like one in SSDE, cutting let's say 12" x 24" vinyl will cause not cut on the right edge or slip-through at the bottom if your design is filled the page.
Here I am attaching the picture of the size and placement that your design should be which you will have to leave 3 grids on the right and 6 grids at the bottom.
If you are cutting your design from its roll, then you can fill it to the bottom with no issue.
Cutting Vinyl with SCAL without or no mat in Cameo
- cutting vinyl with SCAL.JPG (270.55 KiB) Viewed 3628 times
Re: Cutting Vinyl with SCAL without or no mat in Cameo
Thank you, I did not know this.
