How do I join these letters in the software....I want to cut one time
i use union and the text just disappears
font closed help...
font closed help...
- script.jpg (66.51 KiB) Viewed 5019 times
Re: font closed help...
Hi Yahooman....
First you need to drag your box so that is around all of your text. then on the top tool bar you will see tab called path select it then on the drop down you will see right at the top "union" select that and it will weld all the letters together. if it misses some you need to make sure that each letter in each word it overlaping with the one in fornt of it and the one behind it...
Hope this helps....
Susan
Hope this helps....
Susan
Thanks for the answer that works but the o,l,t and h disapear
- after union.jpg (195.17 KiB) Viewed 5012 times
After you type the word, click on the word again, then check the weld option on the right hand side in the "appearance" box.
Thank you will see how that works.....
sometimes I find that those letters with pieces in the middle I have to group them individually first before I weld them....Sorry should have seen that coming....
Susan
Susan
Leo from svgcuts has a great video under tutorials on the main craftedge website all about text and welding
Pandora
Pandora
