Fill in open spots in inkscape to make a cuttable svg?
I tried to search around to look this up but I'm not sure what to search. So when I trace bitmap my image in inkscape it has open spots (black outline is missing in spots). How do I fill in those spots to make it a solid outline I can cleanly cut?
Re: Fill in open spots in inkscape to make a cuttable svg?
I've ran in to this a few times. I normally just trace it myself when this happens. I'll be curious to see if someone has a more efficient way to do this.
My files are for personal use only. Please do not sell my files or items made from my files. Thanks.
Morning - can you post an example of the file you are having a problem with - there are a couple of ways to try depending on the shape of the file and the size of the gaps
Happy to to post methods when I know what it is you are trying to do
Pandora
Pandora
yes, an picture would be best, but you could go into the node view and delete the nodes that are causing you issues. Or path/break apart and then delete the paths that are causing you issues, and then Path/Combine to put it all back together or Path/Union to get just the outline of all the pieces together without deleting all the middle pieces. So, see, an image would be best to help explain what would be the best method.
The paint bucket tool is great for this. Towards the end this video shows how to use it when there are gaps.
http://cleversomeday.wordpress.com/2010 ... ics-video/
Here is the file. My goal is to do a print and cut which I've never done either and put it on an invitation.
Hi, you didn't post the file.
I give up....I can't get it to post a file of picture. It never stops uploading. Thanks for the help
Thanks everybody! I sat all day and watched video after video and finally figured it out! I really appreciate the help! I will post a pic of the finished invites after the weekend.
if your picture wont upload it is sometimes because it is too big, try resizing and save as smaller file
looking forward to seeing the finished article well done for slogging through till you worked it out
