snap to grid doesn't work
Things we need you to know
trisharella
Post by trisharella »
I can't get my snap to grid to work. doesonly work after you paste an image. I'm trying to design a 3D object. It is vital my lines are straight and accurate. Any suggestion you clever crafters?
gj1
Re: snap to grid doesn't work
Post by gj1 »
Welcome to the board, and please...
could you tell us what version you are using and your computer OS information.
Thanks....it all helps for us to look for you.
I tested in 3.031 and it appears to be working fine.
trisharella
I just updated
Perhaps i am doing it wrong
I choose snap to grid, draw a line but i can see it is not on the grid but off on every connection
Thanks for helping
gj1
Post by gj1 »
Have your snap as you want it set,...try drawing your line and then select the arrow key again to select it and go to move it into place and it should just snap right where it should be.
I admit...I rarely use this...so maybe I don't know how it is suppose to work right....but in my 3.031 it does the above.
