Sure Cuts a Lot 3.0 for Windows & Macintosh
sstehman
Re: Sure Cuts a Lot 3.0 for Windows & Macintosh
Post by sstehman »
cmsmith64
Post by cmsmith64 »
Carolyn
gj1
Post by gj1 »
cmsmith64
Post by cmsmith64 »
Carolyn
pastda3
Post by pastda3 »
Louise-Paisley
Post by Louise-Paisley »
cmsmith64 wrote:I'm going to vent ... and just may-be someone has an answer for. I have SCAL2 and SCAL3 and use SCAL3 b/c I have a Silhouette Cameo which is compatible with SCAL3. I really like SCAL3 BUT I do not like going in to change the cutter from SD to Cameo everytime I load up the software program. I DO NOT like having to select layers so I can have the box showing layers. Why the change from SCAL2 where it was there when you loaded the program, plus Cricut always showed up as my cutting machine. I had to seek help from support just so I can have the virtual mat come up full size ALL the TIME. And b/4 I demanded a full size mat to come up, Cameo ALWAYs showed up ...NOW ...NOT. WHY
Carolyn
As for V3 vs V2..
cmsmith64
Post by cmsmith64 »
Carolyn
Carolyn
As for V3 vs V2..
worthart
Post by worthart »
Donna in Montana
Tazz_4
Post by Tazz_4 »
Nice post!
kellybryant
Post by kellybryant »
__________________________
