Paula, see this post.
viewtopic.php?f=4&t=26472Since I don't use the E anymore I forget what the last firmware vs SCAL will support but I'm guessing that if you update the firmware on your E it will not work with SCAL2. You'd have to check on the provocraft site to see if you can find an older version of the firmware to download into the the gypsy.
I did find this list of the latest firmware for PC machines. If you update you E past these it will not work with SCAL.
You are the only person who can change the firmware on your Cricut Personal Cutter, Create, Expression, Cake or Cake Mini. This can only be done by deliberately using the update firmware feature in the older Cricut Design Studio or the new Cricut CraftRoom software programs.
Quote:
If you're happily using SCAL then there is no need to update your Cricut firmware beyond the versions listed below. Keep in mind these are the highest supported firmware version numbers. If yours is a little less, don't worry.
Personal Cutter: 1.34
Create: 1.54
Cake Mini: 1.54
Expression: 2.35
Cake: 2.35
To check your Cricut firmware, just turn it on and watch the display. Depending on the model, you will see something like v.1.3 or v. 1.54 or v.2.3 or v.2.34, etc.
LEARN, GROW, CREATE, SHAREMac 10.12.6 Sierra, eCAL 1.506, ECAL2.023, SCAL4Pro, Export Plug-in, Inkscape 48, iPad/scal3
