Problem with Layout Grid
djamelo
Post by djamelo »
Hi all,
I just upgraded to the latest version and I have the following issues:
1. When I add columns into my layout grid on my default page, it doesn't add to the other breakpoint pages
2. When I click on the page property, I cant see the miscellaneous tab.
3. Also, the alignment of the breakpoint 320 is out off alignment after the update.
Are there any known issues with the new update? Please advise asap.
Please help.
I did not find the right solution from the internet.
Thanks!
Re: Problem with Layout Grid
This is a forum for Sure Cuts A Lot software. From your questions, I have to assume you're using a different program. I suggest you Google the name of your software and some other key words from your questions and you'll probably find the help you need. Good luck.
