Craft Edge
Sure Cuts A Lot Forum
It is currently Wed Jul 17, 2019 6:56 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
Author Message
 Post subject: Re: Scan2Cut
PostPosted: Sun Aug 13, 2017 9:52 pm
Rorysnonna wrote:
Hi All,
Do I need to calibrate my laser for assurance chien each time I do a print and cut? I just tried this feature and it worked fantastic. I mostly cut tag shapes over a printed image. This works better than my Brother SnC. So happy you have added the Zing driver to the software.
Hello!
This is my first time here and i just want to say that I’m very happy to be here and to share my opinion.
Thanks!
Top
 Profile
PostPosted: Thu May 03, 2018 10:20 am
HI
I do have zing orbits and I did all the step for scan2cut excepted I don`t know how to cut and the dots will be my registration mark how,Do I let zing orbit scan the dot or should I use the dot as origin point
please help me it will make big different for me if this work.
Top
 Profile
PostPosted: Fri May 04, 2018 4:13 am
Scan2Cut doesn't work on the ZingOrbit. If you describe your particular application, perhaps I can provide you an alternative method.
_________________
Top
 Profile
PostPosted: Fri May 04, 2018 9:32 am
Thanks for the replay I do wanna use it for Cutting some of my finished stamp and also my finished stencil. I don't work with the diy cutter because usually I work with big size project
Top
 Profile
PostPosted: Sat May 05, 2018 8:29 am
One option is to scan your stamp or stencil into your computer first and then use it as a print and cut project whereby you print before coloring. That way the registration marks can be added in advance. Even with my older Zing that does have the ability to use Scan2Cut, I find this process easier plus it gives me the ability to resize the project to whatever I want before printing.
The other option, whereby you can use an already-colored project, was developed using a different software but it should work with SCAL as well. I want to test it first, however, to make sure it works. I will add it to my To Do list and hopefully get it working and documented for you and others. I'll need a few days, however, so that I can get some other things handled first. But it IS on my To Do list now. :)
_________________
Top
 Profile
PostPosted: Tue Jun 12, 2018 3:57 am
I mostly cut tag shapes over a printed image.This
Top
 Profile
PostPosted: Fri May 17, 2019 10:02 pm
Zing driver is awsome!
Top
 Profile
Search for:
Jump to:
cron
