Craft Edge
Sure Cuts A Lot Forum
It is currently Sun Jan 20, 2019 3:04 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3, 4, 5  Next
Author Message
PostPosted: Wed Nov 19, 2014 10:52 am
Site Admin
All new version 4 of Sure Cuts A Lot and Sure Cuts A Lot Pro are now available with:
- New enhanced interface
- New tools, including freehand, brush, erase, knife, & more
- Stencil tool to easily create stencil bridges
- Type on arch
- Various effects, including 3D Rotate, Bulge, Wave, Wrapper & More
- Additional fill & stroke options
- Multi-line text with text justify options
- Snap to objects
- Rotated duplicate
- and more!
- Works with Black Cat Cougar/Lynx, Gazelle, eCraft, CraftRobo/Graphtec, GCC, Foison, Liyu, Pazzles Inspiration/Pro/Vue, Ramtin, Roland, Seiki, Silhouette SD/CAMEO/Portrait, SilverBullet, USCUtter, Vinyl Express, Wishblade & more
- Export FCM for Brother ScanNCut
- Export SVG for use with Cricut Design Space
- Still using a Cricut with Sure Cuts A Lot 2? You can use version 4 for design work and easily send it to version 2 for cutting http://www.craftedge.com/tutorials/sendtoscal2
Pro Features
- Extended cutting length to cut longer than 72 inches
- Weeding options to easily add weeding boxes and lines
- Tiling
- Duplicate cutting
- Cut by color
- Color layer alignment
- Print & Cut (Contour Cutting) for USCutter models
- 3D shadow
- Import DXF, PLT
Special Introductory Pricing:
Upgrade to version 4 for only $19.99 (regularly $30).
Upgrade to version 4 Pro from version 1-3 for only $99 (regularly $125).
Upgrade to version 4 Pro from version 3 Pro for only $49.99 (regularly $75)
http://www.craftedge.com/purchase
When adding the software to the cart on the purchase page, choose the Upgrade option and it will then ask you to enter your current license information for verification to get the Upgrade discount price.
For more information
Sure Cuts A Lot 4
http://www.craftedge.com/products/products_scal.html
Sure Cuts A Lot 4 PRO
http://www.craftedge.com/products/products_scalpro.html
_________________
- Craft Edge
Top
 Profile
PostPosted: Wed Nov 19, 2014 11:43 am
Can version 2, 3 and 4 all be installed and used individually on my computer? I keep version 2 to use with my cricut .. but if I have to merge 3 and 4 that would be okay I suppose.
Top
 Profile
PostPosted: Wed Nov 19, 2014 12:21 pm
It should install it as a separate application. When you download, make sure you always save your download file for all versions separately so you can always revert back to it if needed.
_________________
Top
 Profile
PostPosted: Wed Nov 19, 2014 12:41 pm
Location: North Carolina, SCAL-3; Windows 7-32 bit; CorelDraw 6x; Corel PhotoPaint 6x; InkScape 0.48.4 r9939
Will SCAL-3 license work with 4? If not, is there an upgrade path/price?
_________________
-DON-
http://www.TeesAndBeyond.com
Custom Garment Printing
Top
 Profile
PostPosted: Wed Nov 19, 2014 3:42 pm
if u hv scal 3 u can upgrade to scal 4 for 19.99 and be able to use ur files.
_________________
Top
 Profile
PostPosted: Wed Nov 19, 2014 3:50 pm
I have SCAL2 to use with my Cricut.
Am I able to upgrade to SCAL4 and still use SCAL2 or do I need to buy it separately?
Top
 Profile
PostPosted: Wed Nov 19, 2014 5:01 pm
You will not be able to use the upgrade on the "cricut". There are not any SCAL versions other than the original SCAL2 if you already own it that is compatible with the cricut.
The compatible machines are listed on CraftEdge's site.
_________________
Top
 Profile
PostPosted: Wed Nov 19, 2014 6:47 pm
Technically version 3 & 4 do not work with the Cricut, BUT you can work in those versions and then send the design to version 2 and cut with it.
Top
 Profile
PostPosted: Wed Nov 19, 2014 10:17 pm
I am truly confused. I have SCAL ver 3. Is it necessary for me to purchase SCAL 4 since I have a previous version? The replies to this are not clear on this question. :?:
_________________
When you come to the edge of all the light there is, and must take a step into the darkness of the unknown, believe that one of two things will happen.
Either there will be something solid for you to stand on, or – you will be taught to fly….
Top
 Profile
PostPosted: Wed Nov 19, 2014 11:51 pm
as I see it this is a new version not an upgrade and when you pass from version to version you pay for it; if you already have Scal3 then you pay a reduced price as someone said of $19,99.
Top
 Profile
Search for:
Jump to:
