Contour cutting
Contour cutting
Anyone know if you can contour cut with sure cuts alot 3 ????????
Re: Contour cutting
yes, it's called print and cut (or PnC for short)
it might be cutter dependant, I'm not sure
when you click the cut button you should see a button on that dialogue that pops up that says print and cut
Gaz
Gaz
Computer:IMac running Mojave
Re: Contour cutting
Cheers Gaz, I'll Give It A Go......
