Craft Edge
Sure Cuts A Lot Forum
It is currently Sat Mar 28, 2020 12:53 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 29 posts ]  Go to page 1, 2, 3  Next
Author Message
PostPosted: Thu Feb 04, 2010 9:10 am
Site Admin
New version (2.010) for Windows is available now on our site
http://www.craftedge.com/download
Mac version should be available shortly.
To update from a previous version 2, just download and install over the current one.
Make sure the program is not already open and running when installing the update.
New Features Added:
* Added Node Editing Tool to edit the nodes/points in the outlines
* Added Drawing tool to draw lines and curves, add and remove points
* Added Pause button to pause in the middle of cutting your projects
* Added Boolean operations under the Path menu for doing Union, Intersection, Exclusion, Minus Front from Back, Minus Back from Fonts between two objects
* Added option to convert text to outlines under the Path menu
* Added Beach and Newborn shapes to the shapes list
_________________
- Craft Edge
Top
 Profile
PostPosted: Thu Feb 04, 2010 5:33 pm
did update, nothing under path will highlight, unable to use
Top
 Profile
PostPosted: Thu Feb 04, 2010 6:15 pm
Peachyscraps you would would have to have two items selected to get the path feature working.. Try with two squares overlapped.. select them both then look in your path option.. :D
Top
 Profile
PostPosted: Fri Feb 05, 2010 8:14 am
any ideas on when this will be available on the Mac version?
Top
 Profile
PostPosted: Fri Feb 05, 2010 1:20 pm
Location: LAFAYETTE,LA SCAL1,SCAL2 ,SCAL 3 Windows 7 64 BIT,INKSCAPE.47,cricut personal.cricut expression
where is the pause button,can't seem to find it.
Top
 Profile
PostPosted: Fri Feb 05, 2010 4:39 pm
Love the new features thanks. Can't get the add nodes to work, i can delete nodes anyone any ideas.
_________________
Thanks for sharing.
Helen
Top
 Profile
PostPosted: Fri Feb 05, 2010 5:35 pm
Does this update fix any bugs? Please see my post about program crashing when moving an item.
Top
 Profile
PostPosted: Fri Feb 05, 2010 7:28 pm
Ever since I downloaded update 2.010, my SCAL2 won't cut. Everything works fine until I try to cut - then I get an error message and it shuts SCAL down. Help! I have lots of things to cut. Can I somehow just delete the latest update? Worked fine before.
Top
 Profile
PostPosted: Sat Feb 06, 2010 4:36 am
I have downloaded the latest version three times. Every time I go back into SCAL2, it says there's a newer version. Why is it not reading the newest version for me?
Top
 Profile
PostPosted: Sat Feb 06, 2010 2:14 pm
You will need to install the file you downloaded.
Make sure SCAL2 is not running.
Run the file you downloaded (double click on it)
That will install the new version over the old one.
Now run SCAL 2, you should now have the new version installed and the message of a newer version should not appear
Hopefully that helps
Cheers
Craig
_________________
Cheers
Craig
Top
 Profile
Search for:
Jump to:
