It is currently Tue Aug 20, 2019 12:45 pm
PostPosted: Mon Jun 25, 2018 5:48 am
I had a website I was working on that was working perfectly prior to the recent update. Now, i'm having an issue with the layout grid with fixed height and flexbox. Unfortunately, I didn't realize there was a problem until I republished it and uploaded it to the server and wrote over the working version online. Also, I did not even change anything with the grid before I uploaded it again.What is happening is this: I've set the background of a grid column to an image with fixed height and use flexbox. Before the image showed up fine in each breakpoint. However now, it only shows up in default view and then disappears in the BP's.Here's a sample project of just the grid (with images included)Simply preview it and you will see the issue. Like i said it worked perfectly up until I updated yesterday.as a note, I have another project I've used something similar and now it is not working.
Please help.
I did not find the right solution from the internet.
References:
http://www.wysiwygwebbuilder.com/forum/ ... hp?t=80111
Online Backup Video
Thanks!
PostPosted: Mon Jun 25, 2018 5:54 am
This is a forum dedicated to users of Sure Cuts A Lot software. Not sure why you're using this forum for posting your issue unless I'm misunderstanding what you're saying. What version of SCAL do you own?
