New eclips2 cutting half an inch to the left
kendium
Post by kendium »
Just replaced my old Sizzix eclips 2 with a new Sizzix eclips 2. Plugged it in and it is cutting half an inch to the left of what my computer screen shows? I am using Sure cuts a lot. Any help fixing this would be greatly appreciated.
Re: New eclips2 cutting half an inch to the left
I'm not an eclips user but in general, when this happens with any cutter, it's based on what that cutter uses as a pointer for setting the origin. For example, if a cutter has a laser light, then that laser light is usually used to determine where the origin is set for a cut. If the cutter doesn't, then it's usually the location of the blade tip.
