Cameo4 and SCAL5
moustique
Cameo4 and SCAL5
Post by moustique »
I will soon receive my cameo4.
I would like to control it with SCAL5 to use svg files.
But in SCAL5, I can only select the cameo3 and do not see the cameo4.
Will it work?
Re: Cameo4 and SCAL5
Please update to the latest SCAL5 version and possibly continue to do so every week as new updates are released. The Check for Update option does NOT work in SCAL's Help menu. You need to go to the web site below and just update. It's fast and easy and doesn't require re-registering. Here's the link:
moustique
Post by moustique »
Thank you for your answer.
I actually thought I had the latest version, and I only had version 5.011 (current version 022)
lamber
Post by lamber »
I updated to the last version by hand and now it seems SCAL5 suppourts the Cameo 4. But unfortunately when i use the autoblade in the maschine, there ist no possibility to select the cut depth. When i select "autoblade" the machine starts with resetting the knive to zero and then starts to cut.
Will there maybe the feature to set the autoblade to a cut depth ?
thank you!
Without the developer of SCAL actually having access to a Cameo, replication of the Auto blade function isn't possible.
