It is currently Sun May 19, 2019 5:02 am
PostPosted: Sun Mar 24, 2019 7:37 pm
Has anyone Scan2Cut a stamped image by way of Adobe Illustrator? In Illustrator I scanned the image, traced it, created a closed path to cut the image, place registration marks the closed path (<path>.REGMARKS), and saved the file as an *.*svg. I placed manual registration marks around the stamped image. My cut ends up skewed. I've calibrated for Print and Cut successfully so I don't think that is the issue. Is it possible I'm not placing the registration marks in the right place or is this a lost cause and I should simply use SCAL to scan and cut a stamped image? I'm using SCAL 4 Pro Version 4.075.
PostPosted: Tue Mar 26, 2019 4:38 am
I would guess you need to use the step-by-step procedure in SCAL in order to make it work. You might want to check out my tutorial in Section 11.06 in this user manual.
https://www.iloveknk.com/0um/ZingAir-wi ... CAL-UM.pdf
While it uses a different cutter, the basic procedure would be the same:
PostPosted: Tue Mar 26, 2019 5:19 am
Thanks!
