Craft Edge
Sure Cuts A Lot Forum
It is currently Sat Jan 19, 2019 6:04 am
Author Message
 Post subject: pathoffset bug or not
PostPosted: Thu Jun 15, 2017 4:08 pm
I was learning the different features of ecal 2 and looked at the path offset tool. I picked a shape from the library filled it with a pattern , all good. I then edit copy and paste next to the original. On the new object I selected path offset of 1, when I hit ok, the program upsized the object to the size of the offset. I would have thought that the path offset would have kept the object the same size but created a cut line outside the image, leaving a white margin around the shape the size of the offset.
Since I'm new to the software, it could be my misunderstanding the offset function.
Wyndham
Top
 Profile
PostPosted: Fri Jun 16, 2017 7:49 am
Site Admin
You will want to use the Shadow Layer effect
https://www.craftedge.com/tutorials/shadow_layer/shadow_layer.php
_________________
- Craft Edge
http://www.craftedge.com
Top
 Profile
PostPosted: Fri Jun 16, 2017 8:19 am
thanks will do just that
Top
 Profile
Search for:
Jump to:
cron
