Does anyone know how I can re-install my ecal software? I purchased it over a year ago en craftedge.com, I than had issues with my macbook and had everything wiped out a few days ago and I now have to reinstall almost everything I had ....
anyone know how I can do this?
thanks...
How do I re-insntall Ecal software ...
Re: How do I re-insntall Ecal software ...
If you did not deactivate the software prior to the computer going down, you will have to contact support.
Or just type to
support@craftedge.com
If your on the same computer but it has been reset to factory settings, then it is like a different computer.
All of the answers are covered in the FAQ's
http://craftedge.com/support/faq/faq.html
You can re-install the program by just going to the downloads page and install and then attempt to activate it using your serial number...but if you don't have that and obviously can't get it off the program now, then you will have to contact support with the required information for them to get you set up again.
Everything you need can be found via the tabs from the Craftedge homepage
http://craftedge.com/index.html
Or just type to
