Print & Cut using the Affinity Design Software and Scal5pro
Re: Print & Cut using the Affinity Design Software and Scal5
Please do. I'd really like to understand this myself in case it comes up again or ever happens to me. It's just weird!
olivia545
Post by olivia545 »
I am getting an issue with the Epson printer from a few days, actually, after inserting the pen drive in the printer I was continuously getting Epson Printer Error Code 0x9d and cant able to find out the solution to resolve this error. Can I have any kind of suggestion of idea from this community?
You're probably better off finding a forum dedicated to Epson products versus this forum which is for a particular software program called Sure Cuts A Lot.
hussain9909
Post by hussain9909 »
Which is the best software among these two?
This is like comparing apples to oranges. Affinity Design is an excellent vector design program oriented towards being used for printing purposes. You can create cutting files with it but then you need to export the design in a format that your digital cutting machine can import and cut. SCAL5 (regular and Pro) works directly with dozens of different digital cutting machines and contains a wide range of functions that are of interest to those who do cut materials, such as vinyl, paper, cardstock, HTV, fabric, leather, and more. Hope this helps!
brotherhl-2280dw
Post by brotherhl-2280dw »
I am getting an issue with the brother printer from a couple of days, really, in the wake of embeddings the pen drive in the printer I was persistently getting the printer in error state and cant ready to discover the answer for resolve this mistake. Would i be able to have any sort of proposal of thought from this network?
This forum is specifically focused on a program called Sure Cuts A Lot that cuts to various digital die cutters. I suggest you find a Brother printer forum to present your issues because there will likely be many more experts there on printers than here. Good luck!
