Print Window Goes behind SCAL window after Print Properties
Whenever I use the PnC and hit the print button, the print window opens and is fine as long as I hit print. If I go to print properties, all the print windows disappear behind the SCAL window. I'm using an epson stylus, not sure if anyone else has this problem.
24" Cougar Pro with ARMS that does not work
SCAL 3.057
CorelDraw X5
Illustrator CS5
Win 7 64 bit
Epson Stylus Pro 7600
SCAL 3.057
CorelDraw X5
Illustrator CS5
Win 7 64 bit
Re: Print Window Goes behind SCAL window after Print Propert
Yep, I always have that too with eCAL. It's not printer related since I have a Konica Minolta laser printer. If you click on the cutting mat the main print window will appear so that you can print.
I used to have those problems too! I've just figured out that I need to have my printer settings correct before I do the p2c, and then it goes fine. Wonder what's up with that? (using ECAL too)
