which model of UScutter have you got??ElnaB wrote:I just purchased a US Cutter and have not got it to cut with the sure cuts a lot 3 I was using my cricket and the software and it worked fine, but I wanted to step it up a bit and have a larger format to cut with. I guess I'll be looking for another software program to run my cutter
Cut and Print button in sure cuts a lot 3
Re: Cut and Print button in sure cuts a lot 3
I missed this sorry. The SCAL3 does work with US cutters but not using the Red dot for contour cutting! For that you will need SCAL3 ProElnaB wrote:I just purchased a US Cutter and have not got it to cut with the sure cuts a lot 3 I was using my cricket and the software and it worked fine, but I wanted to step it up a bit and have a larger format to cut with. I guess I'll be looking for another software program to run my cutter
If you are still having a problem I can help you out!
