Hi,
I am trying to do a Print and Cut project but it does not work.
For one, SCAL does not remember the correct calibrated values, so I have to put those in every time I open the program over again. But this is not that big of a deal.
My biggest problem is that it gets cut wrongly. It is off by 1mm, which is too much on a detailed file like mine.
How do I solve this?
Since P&C does not work, I tried using Origin Point method in cutting. I put the blade in the bottom right hand corner of image to be cut and made that the origin point. I pressed 'cut' and it cut off again! This time by about 1,5 cm.
I have a 13inch Black Cat Cougar.
Thanks so much for any help!
Print and Cut does not work!
Re: Print and Cut does not work!
Hi, consider contacting CraftEdge support about calibrating your machine and how to ensure that the seiitins are saved.
You can find the link along with FAQ's at:
http://CraftEdge.com
Hi there
Have you calibrated your machine ? did you manage to set it to cut correctly ?
Try entering the numbers then close out of the program using File/quit rather than any other method and see if that solves the problem of the numbers not working
good luck
good luck
