Is it possible to print colored digital stamps on a colored printer and then cut them in SCAL.
If yes can some guide me to a Tutorial.
Can you print colored digtal stamps
- Location: PC Widows Vista, Circut, SCAL 2.044, Inkscape 47
Thanks a bunch
Blessings SoulSisterD
Re: Can you print colored digtal stamps
Save the stamp as a .jpg or .png and use File Place in SCAL and the use Trace and trace the same image for the outline and put the outline around the picture. Use Layers Eyes to turn off the outline and PRINT FROM SCAL the picture...lay it on your mat and then use the eye and turn off the picture and turn on the outline and cut around the picture. Some adjustments need to be made for placement of the picture on the mat depending on the machine you are using. Be ready to waste a bit of paper and ink to figure out the proper placement.
Search this forum for calibrate if you are using the older machine and print and cut, and if you are using a newer machine...follow their directions for print and cut. OR, hinge technique for print & cut...
